phatchopper300
I just wanta ride
Describe my problem as short as I can. Riding home a week ago. Starting hearing grinding sound in clutch or primary. When I pull in clutch handle it stops. Or it does it real bad when I give it gas. Pulled primary and checked everything I knew how to check. OK 1 wk later I pulled clutch and all plates and check clutch bolt and forward sprocket bolt and both very tight. When I rode the bike a few days ago.(primary lube with non syn. oil) I HAVE NO SOUND IN 1 OR SECOND BUT AS SOON AS I GEAR UP TO THIRD IT SOUND LIKE CLUTCH AND TRANS ARE MISSING GEARS. Could this be comming due to a loose clutch nut on the muffler side. causing this gear noise. Need help please. And thanks!!!:bang:
