R ROD New Member Aug 29, 2009 #1 My gas cap vents so poory that my 06 mastiff will die even at high speed.I loosen cap and it fires back up.
lee Well-Known Member Aug 29, 2009 #2 on the inside of the cap you will see an allen key fitting. Undo that and remove the white plastic thing. Your cap will then vent properly.
lee Well-Known Member Aug 29, 2009 #3 when you loosen the cap do you hear the air rushing in? If yes, then yes it is your cap. If no, you might have another issue.
BBChopper Supports 2 Disabled Vets Troop Supporter Nov 22, 2009 #5 Very common issue. Raywood was with me when mine did it!!:2thumbs:
