gas tank removal
huffmanlake
How do you get the grommet bracket off the bottom of the gas tank... 2008 Mastiff?? I have a gas cap that won't stop leaking now I need paint work and cant get the tank off.:bang:
Dawgboy
Remove bolts. Use socket extension in center square hole to turn bracket forty five degrees.
Dawgboy
If I remember correctly, one of the bolts is just loosened and the other ( rear I think) is removed.
Dawgboy
Okay, I dug out my manual this morning. Remove the rear bolt. Loosen the other bolt and using a 3/8 rachet with short extension roate the bracket. Slide the tank FORWARD. I place a towel in front of the tank before sliding forward to protect it if it gets away from you. Also, the rubber bushings on the bracket will come off so take note of the orientation so you can replace them if needed. The tips are bevelled asymetrically.
Don't forget about that cross-over tube...
