Headlight
Chris04Masitff
ive looked and searched and think i know im on my 2nd bad EHC. but thought id ask anyway. low beam going out intermittently. when its out yellow fault light on EHC.i checked output on power to headlight and when its not working i have lil over 10 volts. of course when it starts working headlight comes on and i have full batt voltage to light. ive checked wiring pretty thoroughly. this is same thing that happened on previous EHC . checked for good grounds. any ideas. or should i be gettin in touch w Jake (WP time?)
mobsta
the updated one seems to be holding up right now,knock on wood,the headlight was the tell tale sign of that ehc going,i would talk to jake unless you got a hook up on the updated ehc.headlight plug look good
Chris04Masitff
yep ,new headlight bulb, bucket and connector. im gonna throw a switch on it for headlight right now . save some ducks and buy the WP kit.
Chris04Masitff
thanks . i just read Moes thread on bypassing EHC for headlight. sounds like best route for the moment.
