Dogbone
IF LIFE SUCKS, GO RIDE
went for a ride the other day and heard a noise at idle. so while i had a long weekend, i decided to tear down a few things. took off exhaust so i could clean,adjust and grease clutch rod. took off front caliber and cleaned (waiting on parts). done some research about noise and took off primary cover to inspect.. only thing i found is nut holding sprocket on motor shaft seems to be loose. washer behind moves. my problem is it wont turn either direction..:loony: anybody got any ideas....included my fix to not having to pick up primary oil..and a picture of the nut.
