2 pins with roll pins in them going through and a clip on top. If you pull the caliper off look and see how many shims are on each bolt holding the caliper on... Use a C clamp to push the plungers in so you can insert the new pads....
Beer is required...
or Crown Royal Black in my case....
I like the Lyndall pads myself
Neil
