Hubs on 06 RB
phatchopper300
I just wanta ride
OK this is one of the questions that sounds stupid but I need to know. I am replacing my back tire. I removed wheel and all hubs replaced bearings and polished everything. I have noticed on the forum it has been said to mark the hubs to put back in the same position. Well I didn't mark( I know what a dumb ass) hubs. What can happed will the wheel be unbalanced? I have placed hubs on the correct side not just in the exact same spot. :confused:
No problem. Put them back together and you'll be fine. On mine though there is a dot on the wheel and the hubs that I match up.
Thanks Ray. Yea I had no dots on mine. But boy do they shine now!!:D Hope your travels are going well be safe!
Get that thing back together and ride down here. Or I'll meet you half way. Drinks on me
Should there be any slide play on the spacer the long one in between the hubs and the outer bearings
Mine is tight and I have to insert the axle when I lock down the hugs to ensure it's centered correctly
MARV
close to zero play but definitely not tight either.
its a critical part
make sure the bearings are fully seated
phatchopper300
I just wanta ride
its a critical part
Thanks Marv- I had slight play on the inner long spacer. Got it corrected now. What kind of grease would you recommend on the axel.
