See the dimples in the housing and the notch in the cam sensor plate? Line up the notch with the middle dimple -- that should get it started. After that, loosen the hold-downs and rotate the plate to get the timing you need.
It's what's worked for me in the past....I'm sure someone out there has a more complicated procedure.
