installing open primary
ZEDisDEAD
I'm looking for tool to pull a spacer off the main transmition shaft.Does anyone know where i can get one or have a way to get it off.
Thanks,Pat
CCRainman
Use a dremel and cut into the both side of the space. Then take a little chisel and it'll split apart.
ZEDisDEAD
Thanks CC we got it off by using a $40 gear puller set at Harbour Frieght that we modifide with grinder to fit around spacer. Local Harley dealer wanted $220 for tool.That would of been are last option if we couldn't find tool.Will post pictures when done installing 4in. Karata.
