HeyMoose Member Feb 27, 2010 #1 Hey All: Have a loose heatshield --do I have to remove pipe in order to safely get to the hose clamp brackets? Thx...
Raywood The Pirate Staff member Calendar Participant Troop Supporter Feb 27, 2010 #2 Do you still have the stock pipes on it?
BadBrad 2005 Pitbull Feb 27, 2010 #3 Usually, you can unbolt from the frame bracket, loosen the flange bolts and get behind them to tighten up.
V Guru Feb 27, 2010 #4 Depending on the pipe as Ray mentioned either pull it off or get on the floor and she what kind of clmp ya got on the bike somw were crimped
V Guru Feb 27, 2010 #6 HeyMoose said: Mean Mother pipes...lower pipe, front cylinder. Click to expand... See if they are crimped clamps. if so may have to tighten the crimp. also make sure baffle is not loose. That happened on mine
