alhall88
UAW
Getting a jump on some maintenance item and one of them was a slight trans leak I noticed early this year. I thought for sure it was the quad seal that needed replaced but after teardown I'm starting to wonder. I've downloaded the pdf breakdown from Baker but it does not indicate if there is any seal in this area. If I had to guess it looks like its leaking around the shifter arm. Keep in mind the leak never dripped on the ground I just noticed that there was always a wet ring around the lower frame tube and I've never had to add any fluid because of it. I also noticed that the shifter arm is pretty sloppy itself, is this normal? Mainshaft seems solid.
