military decal placement
abnmechny
need some help. where can I find a plate thats big enough to put the post decal sticker on? Also where to put it on the Big to not look out of place?
Top1371
I use a cycle visions plate that mounts to the left fork using the caliper bolts. Some guys have also put their on the back of the lic. plate bracket.
abnmechny
what one did you get they have a couple models. how does it look you have pics of yours?
SAYIWONT
I used an old license plate b/c its thin. Cut a strip just long enough and just wide enough to put the stickers on. Then I used 3M Dual Lock to stick the plate on the back side of the license plate bracket. So, when Im not riding to base its easy to remove and the 3M Dual Lock tape is hardly noticeable.:2thumbs:
MadMarx
The guy I bought my bike from had the same type of setup as SAYIWONT and he also had a plate for large inspection stickers mounted to the rear peg mounting bolt.
Stick
got mine off ebay for 10 bucks last year...only came in black though. Same as cycle visions style that mounts using front brake caliper bolts. Also, the caliper bolts are the same spacing for most new bikes, my 08 Harley used the same exact plate.:flag:
