Dogbone
IF LIFE SUCKS, GO RIDE
Was digging into the primary cause the nut was loose on the motor shaft. The nut on the clutch assembly was also loose and i also took off the stator housing as directed by steve at Alanta Dream and this is my problem. :bang: the pics below show that the teeth inside the housing are all broke off. nothing else seems broke at this time so I would deeply appriciate if someone had a used one to chime in.. :2thumbs:
