Muller Power Clutch
lee
I installed the Muller power clutch in the Heritage for Lisa today - thanks to R&B for mentioning it in the "clutch slip stock" thread.
It was pretty easy to do and is a new inner and outer ramp clutch release mechanism - you use the balls you already have. I had to take the pipes off on the Harley but you may not have to on your bike, depending on what pipes you got.
Straight away it has made a huge difference to the pressure required to pull the clutch in and I read an article on it which says it gets even easier when it beds in properly.
I was going to try and use my belt tension tool to measure the difference before and after but..... I forgot. The difference is big though.
If you want an easy clutch for your dog I would definitely recommend this, provided it will work as well on a Dog, which I cannot vouch for.
Muller Power Clutch :2thumbs:
BigDogBro1
Made in the USA
The BigDogBro2 and I have had the BigDog soft pull clutch installed on both our 2007 Bulldogs. The lever pull improvement is noticably reduced. $185-$200 plus installation. The kit includes thicker metal clutch discs and inner pull lever.
