Need Help Diagnosing
Rineheitzgabot
04 Pitbull
Last night, on my way home my '04 Pit dies, the cluster lights up like in the picture, and will not crank. No click, no grunt, nothing. Any ideas what might be going on?
First thing I'd check is the voltage of the battery. Shows it has volts to code the dash if a red light shows this from a normal white light.
Next are the fuses in the box (if applies) or a relay showing power to it, but does not turn the starter motor over when button is pushed.
Other search is: "WATT was the last thing I did to the bike?"
SCC007
I dont know if yours is falls under this but if headlight and all lights come on with key, check the switch/pcb in handlebar (right side) make sure it is working, also check fuse/breaker under the seat - should be between charge & battery, battery & EHC. Let us know what you find. There is a good youtube video on diagnosis for the handlebar PCB that will help.
If yours is the "harley style" switches then check the run/start/stop (also in right hand side) and sounds like it might be in the run/stop button (rocker switch).
Mikeinjersey
Check your battery connections.Clean and tight and reading 12.8 vdc minimum.
When you get the bike running be sure to check that the charging system is working.If the bike was not charging correctly it would do what happened to you.
