need help on 2004 wiring tailights as soon as i can get it
dantep
Need help as quick as i can in a bad way. I need the order of how the pins fit into the connection on the harness for the tailights. Had to disassemble for a paint job now I need to put it back together. Must have two wires backwards, because all the lights are working correctly except for the left turn signal and when I hit the brakes the left turn signal will not light up. Can someone just relay the order in the harness. for example both the left and right side have reds but not sure if the order I put them in is correct. Thanks
dantep
sorry just got back in. figured it out also figured out I need a new female part of the harness. thanks a ton tho
