need help! rear wheel bearing?
Dimentia
I have my bike on the lift just checking bolts and when I turn the back wheel i can actually hear the bearings roll inside the housing. It sounds like just one of the bearings is missing and the others are rolling into is place..when I turn the wheel real slow it like you can hear the bearing drop down..if that makes sense. I have never heard it before and is this noise normal?:confused:
lee
are you sure the noise is the bearings? could just be your brake rotor - check the pins holding the inner to the outer parts of your rotor
Dimentia
it is a bearing. It sounds like one of the balls is missing and the other ones are dropping as you turn the wheel real slow.....wow sounds like my bike just hit puberty!!!!!
