LA_Dog
Go Fast, Go Faster
Hello everyone. second post here, I have a couple of tech questions for you experienced owners. Just picked up a very clean, low mileage 2001 Pro Street yesterday. All I gotta say is "wow". hell of a bike.
Here are the details:
Bike underwent a through tear down and top to bottom service / update by Threesome Cycles in Long Beach, in 2010. Since then the bike has had 500 or so miles put on it and well cared for. I bought it with 3700 miles on it.
Work performed:
EHC related issues remedied (circuit breakers, complete re-wire, etc)
Handlebar button controls removed
Drag push button start added
1.4 kW factory BDM starter
manual compression releases added
Hooker header system added
Swapped BD rear fender for different NOS BD fender without built in rear light
Arlen Ness stealth2 mirrors
21" front wheel (I still have the 19" as well)
LA Choppers drag bars riser and bushings
Edelbrock 42mm carb
Custom powdercoat frame and paint / pinstriping (all by House of Kolor)
Drag motor mounts
PM brake rebuild kits
CCI swingarm bushings
Heads / cylinders removed and replaced with new performance gaskets
Custom recovering of seat
HHI clutch hand control
Drag throttle cable / housing
Edelbrock intake manifold
New front / rear brake lines
New clutch, throttle, idle cable
New wiring block
CCI HeadLite
EZ Clutch Ramp
PM 9/16 Hydraulic brake control
...Plus a lot of other small stuff like fasteners etc.
After riding it home some 20 odd miles, when I parked I had a good 4" spread of engine oil under the drive side. I took a good look at everything this morning and this is what I found:
1. engine oil puddle was coming from bottom engine breather, the breather filter was fastened to the bottom skid plate under motor. only leaked oil while running. no leaks while sitting. the filter was wretchedly soaked in oil and grime.
I checked the top engine breather, which was routed straight down and inside the skid plate below the motor. the filter looked clean, no obstructions in hose or filter.
I checked the oil level and there is no dipstick. With bike level, the oil comes up roughly 1/2 way in the tank. I don't know if that is high or low.
2. primary cover was seeping pretty good from bottom length of the cover. Also some slight seepage from the bottom of inspection cover. I tightened all bolts a bit to see if that gets rid of it.
3. slight stumble on light throttle. Does not matter what gear or rpm range. idle is strong, bike runs strong. but has a stumble right when you roll on a slight bit of gas, as you open the throttle further it goes away and then rips like a mofo. feels like a carb adjustment issue off top of my head. this has an Edelbrock 42mm on it.
4. I'd also like to know what type of sissy bar will fit this bike. I can't find anything on BD site earlier than 2002. Ya ya I know... the old lady wants one on there when I take her for a ride. So I'm looking for some type of quick release setup.
5. What type of fender fits the front- I want to pop on a super minimal fender just to keep the slop off during long rides. I have the BD brackets but no fender. I don't mind doing some modification work
Anything else I should generally be aware of on this particular bike, and given the work done above? Thanks in advance for reviewing my post.
Here's some pics:
Work performed:
Edelbrock 42mm carb
Drag motor mounts
New wiring block
CCI HeadLite
EZ Clutch Ramp
Here's some pics:
