tried searching clutch problem & they said 2005 & newer with clutch pulled in feels like its grabbing a bit.handles a little loose is adjusting it the same as 05 and up also having headlight issues
I believe your primary should be similar to the Harley adjustment. The one thing he doesn't show is re-adjusting the cable. So adjust the cable after you adjust the clutch. Should have approx 1/8” gap when you start getting tension on the clutch lever. Hope this helps ya...
