No Headlight
turk1
08' Mutt having some electrical issues. Three weeks ago I lost low beam and found a wire rubbed through inside the bucket. I taped it and it worked fine but as a precautionary measure with it still under warranty I took it in for service (Mistake NO.1) as they replaced the wiring harness two weeks ago. Sunday while riding the headlight went out and the hi beam indicator is flickering on the speedo.:angry: As I begun to remove the ring to again look in the bucket I noticed the allen set screw is stripped and I can't get the S O B out. Eventually I'll get it out but does anyone know where I can get a replacement screw to hold the ring in? Did anyone experience this same issue with no headlight and a flickering indicator?
Turk1
turk1
OK so I got the ring off after much cussing and found the connection came off the back of the headlight. So all is well. Now all I need is another set screw to hold the ring in.
chacha
Chaff Your EHC!!
I've tapped out my set screw hole to a larger size and picked one up from Ace hardware....
