JDPnTN
Hey guys, it's been a bit since I've been around but finally started getting a little time to ride again. Haven't had issues until the other day. Roll my bike out to take my daughter for a little spin. Started right up with no issues. Had a nice little ride with issues. Stopped for a little pizza, and went to leave. Light and speedo (Dakota Digital) came on normal. Gave it the crank and got the clunk. Mashed the compression valves and nothing. Not even the click. Then speedo and lights went out. Trailered home and have been looking up threads but just didn't see any with my same problem. If there is one please direct me there because I don't want to waste someone's time rehashing old stuff. My battery is less than a year old. I have 12.7 volts. One of the big issues and maybe biggest clue is SOMETIMES the lights and speedo MIGHT come on when I turn the ignition on or while messing with moving some wires. I cross my fingers and give it a crank and all I get is the compression valve click then all electronics shut down again. EHC lights are showing on power(steady) and controller (flashing). Ignition stays red when run pushed in.
I've checked connections at battery, put more grease on the ehc pins, and checked voltage at solenoid. There I also have issues. The other day I checked it and had 12 volts coming through. The speedo and lights came back on for first time when testing this. I was relieved the ehc seemed to be doing its job. Today however I'm only getting 9 volts. It's like when I think I'm going in the right direction something else happens to pull me another. Really don't think it's my starter or solenoid because I don't think that would interrupt my electronics the way it is. By the way not much of a wrencher unless obvious things, but even less of electrician. If someone could send me in right direction it would be very appreciated. Never had it happen like this before. Thanks!
