Not starting at all. 04 Ridgeback
bluebeard
Picked up an 04 ridgeback a couple of months ago.
Went from having absolutely no problems, to just nothing.
Grabbed a brand new battery to make sure that's covered.
Rebuilt the solenoid, which was bad anyway.
Turn the key on and I got the blue light on the EHC.
Hit the run button red light turns on on the thunderheart ignition control module for a second then it shuts off.
Press the start button and the red light on the EHC lights up, and the automatic compression release engage but that's it.
Under the Sea of the EHC, the thunderheart ignition module, and what looks like a 30 amp relay. Not seeing a start control module at all.
Swapped out the relay, going to go by the garage today and get one that I know is good and try that again.
Was assuming all the controls on the bars are functioning fine because every time I'm pressing a button it's doing something, I did notice that my right blinkers aren't working at all.
Worked on shovelheads for years but when it comes to the computerized electrical stuff I'm completely in the weeds.
Looking for any advice or help I can get.
Also if anybody knows where I can get manuals, or or a parts manual book that would be a huge help.
Jersey Big Mike
100K mile club
turn key on and remove green wire from starter
jump 12v to location on starter where the green wire was to see if starter works since you worked on the starter last and you say you only get the compress releases opening.
