Oil change
stlmikie
I wish I had more money.
I started to change the oil. When I took out the oil plug hardly anything came out. I tried to stick a little screwdriver up into the hole to see if there was an obstruction and there is something big blocking the hole. I have no idea what it is. the oil bag is full and the oil came out od where the filter is. I am in a bind. Any help would be great.
Dude, did you remove the plug for the oil tank or the motor? The oil tank on my 03 had a rubber hose mounted to the frame that you removed a plug from and it drained the tank. This would be on the right side of the frame under the tranny.
stlmikie
Yeah. So I am slightly retarded. Ray you got it. I took the plug out of the bottom of the motor. I got it all down now.
LDO
The Cleaner
I thought about that but you should be able to see that it's a plug. By the description Mike gave, it seemed no oil came out AFTER he removed the plug.
oh well, glad you figured it out.
stlmikie
Yeah I took the one out under the front of the motor. Not the one on the end of the hose.:bang: I got it all squared away though. I have a fried now that works at the dealer here in the STL. Hell of a guy. I've been calling him when I have questions the whole way with this bike. I finally had the guts to just ask him over and help. He didn't hesitate. I know that is kind of taboo for the shop help to help out of the shop. Guy is brilliant. Had me up and running in no time.
barhopper
Another round please
My 04 is the same way. :cheers:
