Oil Cooler Help
abnmechny
well I finally got my oil cooler in after waiting since Mar. The instructions and pictures arent the greatest. So I have a few questions:
1. What line on the filter housing do you use?
2. does it matter what line goes where on the oil cooler?
3. how much oil will come out?
does anyone have any pics of the connections???
08mastiff
There are two lines going into the filter housing. You have to unscrew the line that is towards the outside closer to the brake (called the outer fitting return), not the one that is against the engine. Just unscrew the line and not the coupler attached to the filter housing. Once you take that line off you have to screw the male coupler that comes with the kit in the end of the oil line. You then screw the shorter of the two lines provided (9" line) with the kit into the coupler. The other end goes to the cooler. You should be left with the longer oil line (18" line). The one end goes to the cooler and the other end goes to the filter housing replacing the line you took off. It doesn't matter what line goes into the oil cooler. Very easy install.
As your doing this you will see steady drops of oil coming out throughout the install. Can get messy. Good luck.
