Oil Leak
Ridin Dirty
06 K9 has developed an oil leak sitting in the garage. Its right in front of the back tire. Not a bad leak but gotta fix it. Any help or suggestions would be greatly appreciated. Thank you in advance!
Ridin Dirty
Banned
any idea where its comming from?? oil lines,oil tank,primary, tranny?? we might need alittle more to go on.. clean it off & watch to see where its comming from...
Ridin Dirty
Had the girl tonight because wife is working so I did not get to track it down. Just driving me crazy so I thought I would post something. I'll try to track it tommorrow and get more info!
N8KAM
I have had the oil line leak at the oil tank...
or it could poss be the starter "Shaft seal" and dripping out of the starter
narow37
Angry Southern White Man
check the ends of your shocks as well. that oil will be a grey/dark silvery color.
BadBrad
2005 Pitbull
You're the only one that can diagnose where the leak is coming from. It could be one of several fluids coming from a dozen different places. Anything from a loose primary case, drain plug from primary, rocker boxes leaking, oil line, oil plug, pushrod covers, and the list goes on and on. Wiper 'er down, take it for a short spin and get a good light and go over it to find your leak, then we can give you some ideas on getting it fixed. Good luck.
bruce
It's most likely from the bottom of rear cyl. rocker box, a common leak, I had to fix on my 06 K9 last year.
bruce
no can repair on bike, you will have enough room didn't have to remove anything not even tank, only thing I had to do was cut down a allen when I was torguing everthing back on.
Willy Hank
My 05 chopper plus many other 05 choppers had oil filling up their starters from the primary. Required an improved starter with a seal. Not sure, but that is where the leak was showing right infront of the Rear tire. It drove me nuts until I hunted it down here in the blogs. ebay'd a new starter with seal and no issues since. All this was the result of 04 left side to 05 right side drive conversion requireing BDM to slim down and lower the Starter to Primary location.
BadBrad
2005 Pitbull
That's where DSSC comes from. The first two letters? Dropped Starter
