Top1371 Active Member Jul 15, 2010 #1 for an 04 Ridgeback. Do I need a BDM specific gasket or will an HD work? If so which one?
0 03blldg New Member Jul 15, 2010 #2 not trying to hi-jack your thread but is the gasket a one time use thing if i take it off to check internals
Top1371 Active Member Jul 15, 2010 #3 I think you can re-use them, I just want to have one handy just in case.
Raywood The Pirate Staff member Calendar Participant Troop Supporter Jul 15, 2010 #4 04 and earlier are all HD compatable. For the record I've pulled my primary cover and re-used my gaskets/seals many times without problems.
KaptinAmerika Guru Jul 15, 2010 #6 As long as the gasket isn't severly damaged you can clean them and reuse them continuously. Just make sure you apply enough sealant on the inspection cover gaskets and correctly.
