pushrod adj.
tpir33
I am trying to re adjust my pushrods and have been following chacha's how to on this. Should I follow this step by step if I am just re adj? Or Is this how to from the very beginning.
If your adjusting your pushrods then your adjusting your pushrods. Follow it start to finsih everytime.
tpir33
Just wasnt sure. Was folowing it step by step Tightened a pushrod 3 turns waited for it to bleed down and could not turn it with my fingers. My question is where to from this point?
Little-Boo
OK you need to loosen the push rod first, then start the process of adjusting 3 turn and not more than 4 turns. Then you wait 20 minutes or until you are able to turn the push rod with you fingers. Do not attempt to rotate the engine if you cannot turn the push rod with your finger you will end up with a bent valve. It take patience to do this and double check you work too.
Carlos
tpir33
Thanks carlos just needed some insight where to go from the point I was at. I will start from the top.
Brew
I have a question on this process. I adjusted mine to zero lash, waited a few mins then adjusted with 3 turns, then waited 25 mins, but the push rod was still tight. So, I loosened it till the push rod could be turned with my fingers (not loose but snug). Now my question is, may this be an indication that I have collapsed lifters? Keep in mind I did do this with the bike several days cold.
outdoorsman26
brew454 you may have limiters in your tappets?? raywood just put a thread on how to do this!! it took me a couple of tries before I got it right dont give up and when you try a different way save it/ write it down and after a couple of times you will be a pro at it!!!
Little-Boo
This comes from a post by Raywood follow these instructions and you should be good to go.
Bring Cam to Base circle for the tappets you wish to adjust. You can do this by rotating the motor over till you have dual movement of the pushrods for the other cylinder. One should go up the other should go down, either way at the same time. The cylinder that you’re adjusting, the tappets should be on base circle of the cam, lowest point in the tappet block for the tappets. Adjust the push rods as such.
Zero lash the pushrod, no up and down movement, tight against rocker arm, and tight against tappet/lifter.
Mark the push rod with a marker or paint stick. Extend the push rod four full turns or 24 flats (if using S&S Push Rods, S&S push rods have a thread pitch of 1/32”)
Allow the tappet/lifter to bleed down 20/30 minutes, longer is better.
If after 20/30 minutes you can spin the push rod with your fingers you do not have limited travel tappets. Locks the push rod down, you are now done adjusting. Move on to the next. Repeat process for the other cylinder and push rods.
If you cannot spin the push rod, you have S&S Limited Travel tappets. From this point you want to shorten the push rod. While shortening you will feel drag on the push rod, this is the valve spring tension. While shortening, you will feel the valve spring release the push rod; at this point you should notice it being easier to spin the push rod with your wrench. From this point you want to shorten one full turn, 6 flats. At this point you should be able to spin with your fingers. Lock down the push rod and repeat for the rear cylinder. Do not try to make short cuts in this process. Proper bleeding down of the tappets is critical for healthy running motors. Damage to motor will happen not following these instructions.
Carlos:whoop:
Brew
Well, that's good new information! I better re-do mine. Thanks everyone for the heads-up! I didn't see any of this stuff in the S&S manual or the maintenance manual...:2thumbs:
tpir33
Got everything adjusted and things seem to be right on. Just wanted to say thanks to Chacha for the how to with pics and Raywood for posting the adjustment procedure for the S&S Limited Travel tappets.
