Quick Question
FST954
I know it has been discussed a thousand times I really don't feel like doing a search. I want to change my motor oil and I have seen many different ways of doing it. I just ordered my manual but I want to change it this weekend.
I have an 04 RB I see the oil pan at the back of the motor (In front of back tire) at the bottom of that I see the drain plug is that the only place I should drain it from? And yes I will be changing the filter also.
Thanks
erldawg
Thanks
Search "How to Service your Big Dog" by gas man
It would have taken you less time than starting a thread....just saying
avdhunter
No you will find it a little different for your 04 RB than some of the pics in Gas' thread. Like the drain for the oil...it sounds like you have located the right one. Also there are differences in your primary and transmission when you go to service them. Once you get your manual it will fill in the gaps. The reason for the differences is that gas' pics are from an 05 chopper or K-9.....hope this helps!!!!!
FST954
I appreciate everyones input as I have said before this is one of the more informative websites, not only is it informative you never get a bunch of a** hole comments
LARS
sippin & cruzin
We are waaaay to mature for that…………………ya bunghole:D,,,,,F-d up Friday:cheers:
FST954
Changed the oil today all went well was not hard at all I am petty mechanical I just like to ask questions to make sure it is done right. No question is a dumb question next is the primary and trans
Thanks everybody
