2005 Chopper
2005 Chopper with 117 inch motor takes really long to warm up. Have to keep adjusting the enrichner for a good 10 minutes. Any suggestions on how to improve?
Should not have to use the enrichment at all. If you do then you carb adjustments are not correct. S&S has a good video on youtube on the basic setup for the super G. Follow their instructions and then you should be able to fine tune the carb to start without using the enricher. Also your bike looks like a ‘04 chopper not ‘05.
I would move the intermediate jet up a size. Everything seems to indicate that it is too small. If you turn the screw out and it doesn't stumble, you need to move up a jet size. A lean engine will take a long time to warm up. You said the plugs look lean. That would make sense. I would try a bigger intermediate jet first before the rebuild.Well I went through the S&S basic set up and it didn't seem to help any. It seemed like when adjusting the idle mixture screw when I turned it counterclockwise the RPM went up a little bit but did not stumble no matter how far I turned it counterclockwise. Runs great when it's fully warmed up. It does have an occasional cough at high speed. Pulled the plugs looks like it's running a little lean. Figuring on trying a rebuild kit. Any other thoughts??
