stevepro
I seen a couple post on rear rotor replacement, but being a first timer does any one have a more detailed instructions on how to do this. Do you loosen the nuts on both sides? Which side does the axle come out on? I can see how to remove the caliber and I also see the allen screw that hold the axle. I have seen comments about 2 allen screw on each side I only see the one on each side and I removed it and it is the one that goes all the way through to hold or lock the axle. Does the entire wheel need to come off for this or can you just push the axle through far enough to the left to replace the rotor. I have a 2003 Mastiff left side drive with a floating rotor that rattle like hell!!!!!!!
Thanks for any help.
Steve
Steve
