Chopper 65
Hallo from germany, i Need a gasket Kit for Rockerbox on a 2005 Chopper 117cui . Its Not the Same like on a 2007 or 2008 . Why is it so ?
Thanks for help
Chopper 65
Thanks for help
Chopper 65
In 05 and 06, Big Dog was assembling their own S&S engines in-house. They chose to use TP rocker boxes for some reason. Are the rocker boxes leaking? If so, find out where it is leaking exactly. The usually leak from the lid. Curtis at wildsteedworx.com has just the lid seals. It is a much easier and less time consuming fix. He also has the complete gasket kit if it is leaking at the base of the rocker boxes.Hallo from germany, i Need a gasket Kit for Rockerbox on a 2005 Chopper 117cui . Its Not the Same like on a 2007 or 2008 . Why is it so ?
Thanks for help
Chopper 65
Das Fahrrad auf Ihrem Profilbild verfügt über S&S-Rockerboxen. Wenn es sich um das Fahrrad handelt, von dem Sie sprechen, müssen Sie den S&S-Dichtungssatz kaufen.
[/ZITAT]
