This is what the Tach Ring looks like from behind. Check it out for a cold solder joint or broken wire.I still have high and low beam. Just no indicator lamp
When you reassemble it use some dielectric grease.Got it working. Thanks guys. I think it is a loose connection at the plug inside the tach housing. Wiggled those plugs and it started working...after removing the tank and checking all that stuff first LOL.
