reddog06 Member Mar 10, 2010 #1 hello my brother , anyone know how to check the timing on a s&s 117 engine ? just put new 600 s&s cam ? thanx jim
Raywood The Pirate Staff member Calendar Participant Troop Supporter Mar 10, 2010 #2 Unless you have an aftermarket ignition all BDM bikes are locked. If you want to upgrade the ignition see Jakes (BDMRidgeback) thread in the "How To" section on installing the adjustable Thunderheart that is a direct replacement for your ignition. Welcome to the forum.
BBChopper Supports 2 Disabled Vets Troop Supporter Mar 10, 2010 #4 Bad timing on that intro!! Welcome!:2thumbs:
outdoorsman26 Well-Known Member Mar 11, 2010 #7 like ray said its locked but when you put your cam in you lined up the tick marks right???????
bdmridgeback Low Down Chop Shop Apr 1, 2010 #16 Welcome, and here is a quick link to it: http://www.bigdogbiker.com/forums/how/7950-how-upgrading-thunder-heart-ignition-module.html Hope that helps
reddog06 Member Apr 1, 2010 #20 dude thats so awsome ! i really appreciate that info thankyou some much! jim
