Rottweiler
I have a 2004 Chopper and just replaced the cam sensor. What is the best way to check the timing?
where do I get this timing module?This is what I found in the 2004 service manual.
1999 to PRESENT TIMING PROCEDURE - THUNDERHEART
Big Dog motorcycles use an electronic ignition system that MUST BE timed utilizing a special
timing module. The following is the procedure that should be followed to insure that the motor
is timed correctly:
STEP ONE: Remove the seat and dash to gain access to the motorcycle’s installed ignition
module and battery. The ignition module is mounted forward of the main harness module
(EHC), and is about the size of a business card. (When the power is on, and the motor is cranked
over, the LED located on its top will blink off and on. This indicates that the sensor plate pickup
is generating timing pulses and the module is receiving them.) Trace the harness wires that exit
from the module to their connection with the sensor plate harness wires located near the nose of
the seat between the right side gasoline tank and the frame. Disconnect the motorcycle’s ignition
module and plug in the timing module. Connect the ground clip to a suitable ground or the
negative battery post.
STEP TWO: Hook up an impulse timing light. Remove the timing plug located on the motor’s
left side over the primary drive. Remove the two screws that attach the timing cover to the nose
cone. Loosen the two stand-offs that secure the timing plate so that it can be moved. Start the
motorcycle, bring the engine to 1500 RPMs as one person slowly rotates the timing plate
counter-clockwise while another person looks for the FI mark on the flywheel to come into the
front (forward) portion of the timing hole. The plate should be secured when the front cylinder
full advance firing mark should be JUST STARTING to LEAVE the front of the timing hole.
(See photo above.) Remove the special timing module and reattach the wires to the motorcycle’s
ignition system module. Replace the timing plug, dash and seat. Return the idle speed to 1000
RPM.
Do I need a special timming light?
