speedometer lights
EJ
I was wondering if anyone has had any trouble with there speedo lights going out. We rode and everything was good then I took her home and put her up then the next night was going to ride to work and no speedo lights. The speedo runs through its paces and the odometer and trip works. I saw some threads on the newer speedos but not like mine. I have the old one on my 02Bulldog no tach or anything. Thanks in advance.
LDO
The Cleaner
EJ,
did you check the connector to make sure it hasn't come loose? You need to pull your 'dash' panel and check that badboy out!:D It's a funny little connector (if it's like mine) and may be comming loose.:2thumbs:
