Stopped running
Jeffray
04 mastiff cranks up then runs a few seconds, shuts off. Head light stays on. Acts like a tilt switch activated. Any ideas couple of different people say coil.
Mikeinjersey
Welcome from NJ.
This file may help you. Make sure you have your fuel turned on and the hose is not clogged. If the bike has been sitting and has a carb you may need to drop the bowl and clean it out and make sure the float is working and letting fuel in.
Yes, it could be an electrical failure, ie ign module, coil, or cam sensor but they usually fail after they get hot not after a few seconds.
Troubleshoot a little and get back with your findings or success story.
