ChopperFred
Hi guys. After a search, I couldn’t find an answer to my issue so I’m putting it out to the Forum. I have a 2004 BDM Chopper since new (left side drive). I’ve been learning to service the bike over the years but consider myself an amateur in that area. Anyway, I just finished the 15K service including adjusting the clutch which I’ve done before. The problem is that with the rear wheel elevated, I cannot rotate the rear wheel by hand even though the clutch lever is pulled in. If I put the bike in neutral, I can rotate it easily. I repeated the clutch-adjust again, but nothing changed. I thought that perhaps the starter gear is not retracting so I pulled the outer primary, and it looks OK.
Could it be an issue with the clutch hub nut or the tranny ball and ramp? If so, what changed? The bike was running fine before.
Thanks in advance.
Fred
Thanks in advance.
Fred
