'The' Most Expensive Motorcycle Battery Made?
Ernie12
My K9 came with a Banshee so that is what I have for now. Every two or three weeks I put in on the Lithium charger for about 15min and its topped off and no problems so far. Make sure you read up on how to maintain the Lithium battery. When its needs replacing I will get the Deka.
haze324
Lithium technology is where it’s at. The new XS Power LI-S series is incredible, a small boutique brand that works great is EarthX. Neither cheap both awesome tech.
Little-Boo
I use the TR-B1500 (Tomioka racing Battery). Its a 4 cylinder car battery and it lasts about 4 years if you keep it on a Battery Tender. The size Fits right in on my 2006 Mastiff, cost about $215.00 plus shipping.
Weight: 15 lbs
Product Dimension :6.9 inches / 176mm x 3.5 inches / 89mm x 6.2 inches / 158mm
Voltage: 12
Full Charge Voltage: 13.8
CCA: 465
Capacity: 17.5 Amps/Hour @ 10AH Rating
Carlos :chopper:
