THUNDER HEART EHC AND MICRO SWITCH
DODGER
We wired the EHC and tried to use a relay for high low beam but does not work with BDL monentary micro switch, also same for Run/kill switch. I was told by Thunder Heart that their micro harness latching controler only works with the micro harness and i need to get a latching controller elsewhere. I found the Wire Plus Dual Latching Module and I am not sure if it will work. Has anyone used the module with the Thunder Heart EHC? I tried a search but did not find the answer.
Thanks in advance! :cheers:
