I know on the inspection cover torque values are 108 inch lbs but if you have a square gasket for the inspection cover you torque to 25 inch lbs. then up to 35 inch lbs. not to exceed 50 inch lbs.
If you have a square gasket on the outer primary in lieu o-ring gasket do you torque less than the 100 inch lbs for the 14 screws?
I have 06 Pitbull.
I have 06 Pitbull.
