Transmission freeplay
f-okie
AllGaveSome-SomeGaveAll
Ok guys, here's the deal. I was doing some work on my open primary. In order to spin it, I removed the plugs and put the tranny in 6th. My question is: in all gears there is about an inch or so of freeplay at the rear wheel when I spin it. Is this normal? I know-stupid question, but I don't know. Thanks guys:flag:
erldawg
While spinning my rear wheel I have some play as well. Normal? IMHO yes.
My preference is to remove the primary cover and use a socket and ratchet to turn the engine over. That way it's easier and you get to change the primary fluid as well. Yes I know you have an open primary however seems like you should be able to accomplish the same by removing the covers.
