Trouble adjusting rear tire
kwhit13
Okay, my belt tension is loose so I decided to adjust the tension. My problem is my adjustment screws will not budge. It doesn't look like the screws are bottomed out and yes I did loosen the rear axle bolts. So where am I screwing up?
mobsta
the first set of allens are the locking screws,pull those all the way out and theres another set of set screws for adjusting
1mndg
RIDE IT HARD!!!
If your adjusting screws are like mine, there is two on each side. The first one is a lock screw and the second is the adjuster. Back the first one all the way out and check for the second one.
kwhit13
Thanks. My old bike didn't have a second screw. I was afraid to back out the screw, should've done that after all.
