SBMike
I have a 2007 K9 with the 117. The previous owner had a 585 cam put in it. Last fall I could hear what I’d best describe as a sewing machine sound which seemed to be in the top of the motor that I’m sure was valve train noise. It wasn’t bad and I assumed it was normal. I finally got the bike out today and after it warmed up I still had that noise but also now it’s kind of a chirping noise with it, but seems to be only while decelerating and idling. But this noise IS annoying. I adjusted the pushrods to 19 flats which is a hair over 3 turns. No change. Now the one thing I did notice is I didn’t have to wait between adjusting each for the lifters to bleed down. They were spinning almost instantly. I’d say 30 seconds. By the time I got the lock nut tight they would spin. Could it be my lifters arent holding pressure? I cleaned the little filter by there and it was clean when I pulled it out. Any ideas would be appreciated.
