To verify if it's the same motor that came with the bike? Or if it's a 117 ci?Is there a database or a way to contact BDM to verify the number on the motor
Just throwing this out. Is the engine serial # on the title? If so compare to title.S&S in Viola Wisconsin would be able to tell you if the number on your motor (the serial #) matches it's sale (or shipped to) BDM for installation in a BDM Motorcycle.
They have a cross reference database that tells them if that particular serial numbered engine went to BDM and was installed in a Motorcycle that was manufactured by BDM in a particular year .
Vince
that's assuming the bike is paid for and the title is in hand.Just throwing this out. Is the engine serial # on the title? If so compare to title.
I just swapped engines and registered them yesterday (in California). I had to go to the DMV and have the engine swap verified on both bikes. Next I had to get a new title with the VIN# and Engine Serial Number printed on it. The title does not indicate the original engine number so you can't automatically assume that a title represents the original engine..... Of course, common sense comes into play in my case because the Big Dog now has a Harley engine in it and my Fatboy now has my S&S in it.Just throwing this out. Is the engine serial # on the title? If so compare to title.
The Engine has it's Own serial number Stamped On The Engine Case.Just throwing this out. Is the engine serial # on the title? If so compare to title.
You're correct but it depends on which State you register the bike. In California, the title has both the VIN# and Engine# on the title. Read the post I wrote above yours if you want to know how I know this.The title has a VIN #(not the same thing).
Vince
No sweat Brother....You're correct but it depends on which State you register the bike. In California, the title has both the VIN# and Engine# on the title. Read the post I wrote above yours if you want to know how I know this.
You can call S&S Direct-they will help you with an engine origin I.D.I checked the title it's not on there. Anyone have a contact at BDM or BDPP, that may help?
X2 and they are very helpful :2thumbs:You can call S&S Direct-they will help you with an engine origin I.D.
(608)627-8324 is the Tech Line number
Vince
