voltage regulator
johnh
i have an 07 bulldog, that appears to be in need of a voltage regulator. the shop manual states that you shouldn't use a shunt regulator on a bigdog. what is a shunt regulator? also, any ideas on what is the correct regulator for my application?
Johnnieye
did you run the test with a volt meter & sure that the vr is bad. I thought mine was bad, but while running the test I cleaned the connection where the vr goes into the engine block and it turned out that the problem was a bad connection. Sorry, don't know what a shunt vr is or which is the correct vr. Good luck, somebody on this forum should know though.
RubWhore
Asshole Extraordinaire
84 up Softail and dont buy nuthing but Cycle Electric less you want to change it again soon
