What do EHC lights mean ?
Svahna
I have starting issues and suspect the starter but just want to ruel out EHC trouble.
What do the EHC lights mean:
I have the new type EHC with 18 lights and when I turn the key Yellow
"power light" comes on and the green "controller on light " comes on but keeps blinking. Is this normal ??
I have a 2006 ridgeback.
>Jimmy
Yes it is normal. Also when you press run a red light will light. What type of starter problems are you having. Need more info
Svahna
Thanx Ray , I had found that also just didn´t understand what lights are ment to be on or of when in normal state ( I have a little problem with the language, I´m Swedish you know )
Mickeetwo:
I have another thread about the starter problem but I think I´ve found out it is the starter that´s gone bad.Just needed to rule out the EHC.
