410strokerss
What kind of starter came on a 5sp 107 S&S 2001 boxer? ? looks like a spyke... anyone got any idea what kw rating these are?
I have been having starting probs after battery crapped out and determined Voltage regulator is bad also...
now with my new odyssey batt installed ..cleaned contacts in starter solenoid and getting 12.8 volts to starter lug 12.6 to trigger and good ground the starter isnt turning over the motor...but will with the plugs removed for a lil while...
bike has 7500mi guess these things dont last long...
also does anyone have any idea what kind of primary gasket set i would need to order? have seen 20 diff kinds on JP Cycles and have the square shape center inspection cover..are they prettty much the same or what?
Thanks for the help in advance guys
