Doogan
I know without looking into the problem I an't fix the problem, but just looking for some insight on anyone's with a similar problem.
2008 Mastiff- Love my Mastiff, but is trying my patience.
New perfect condition lithium battery installed last year- cranks amazing. One this year I had no power with the key on. Nothing powered. I tried a quick boost to verify battery power and no power. Didn't have time past that to look into it. Went back a day later and it powered up and ran like a beast. Another time after it started the bike lost all electrical power but continued to run. Tach and speedo and lights shut down and turn signals were flashing. Shut down and had no power. Pulled seat to see if ECU had lights on and when I touched the harness it was not loose but when I turned the key, everything power up. Engine never shut down while it was running. Is this the typical signs of the harness and ECU dropping out?
Second thing that has happened, out of the blue it will fell like it drops a cylinder here and there. Comes and goes, but never at idle and never when I get it in the garage to start checking for spark. Dropped cylinder feeling is not consistent and is here and they as one off misfire. No pop though exhaust or through carb.
I know nobody here can tell me exactly what is wrong, but maybe with someones experience of this it can push me in a direction. I appreciate the input from the members here.
Thanks for your assistance. It has always given me positive results.
