Olde Man
I installed new bearings in the hubs and when I went to install the hubs and the wheel together I noticed that they did not want to pull together. It was as if the spacer in between the bearing was too long or the bearing were seated too deep. About .025. Do you have to assemble the hubs together with the spacer in between to control the depth of one of the bearings to prevent side loading? What assy method did BDM use? It doesn't seem right to tap the bearing back and forth on the inner race to arrive at an acceptable side load. The installed wheel seems to turn OK but you can not turn ther bearings by hand before you install it. Thanks.
