wheel spacers on 330 tire?
ok, i had a new tire put on and and i think that the guy put the spacers on wrong. which go where? i have tried to find it on here , but cant. the spacing between the tire and finder is off now. also, what about the front wheel spacers? looks like the same thing has happened if it is possible. would the cause it to pull to the right?
lee
if the spacers have been put on wrong it would have a knock on effect. For example, your rear pulley wouldn't line up with the front pulley and your belt would be all over the place. Are you sure it's wrong?
the front pulley is a good bit wider than the back, it looks like the belt is more to the outside than in the middle. anyone?
avdhunter
Seems like this would cause issues with your brakes too. Look at the spacers and see if there is a big dif in them. If the tire looks like it is pushed to the right and the spacer on the left side lookis bigger than the right one then pull the axle and swap sides with them and see what that does.
there seems to be a small difference in them. the brake caliper just rests in place and is not fixed so it looks like it has some freedom to move. i just want to make sure before taking it apart and putting it back together. thanks for the reply
V
What Lee said and on my 08 the rear belt is only about a 1/16" of a inch off the tire. You might check that as well. As far as the lean or pull when riddin the back tire could be out of line after the install.
